cambio de motor
Old Feb 15, 2024 | 06:43 PM
argentina2024's Avatar
cambio de motor
hola buenas tardes
queria saber si me pueden ayudar tengo un HHR 2006 LS el motor golpea después de las 2500 revoluciones
quiero cambiar el motor por uno nuevo que consigo y es del HHR 2007 es un GM 2.2 L61
lo que el motor 2007 tiene una entrada arriba en el árbol elevas una conexión eléctrica y el modelo del carro no tiene esa conexión
bueno si alguien me pudiera ayudar
Old Feb 15, 2024 | 08:09 PM
hello, good afternoon
I wanted to know if you can help me, I have a HHR 2006 LS, the engine knocks after 2500 revolutions.
I want to change the engine for a new one that I can get and it is from the 2007 HHR, it is a GM 2.2 L61
Since the 2007 engine has an inlet at the top of the tree, you raise an electrical connection and the car model does not have that connection.
well if someone could help me
Old Feb 16, 2024 | 06:26 AM
Basic 2.2 engines will swap you will need to reuse the 2006 ignition box and sensors
Old Feb 16, 2024 | 03:30 PM
PulpFriction's Avatar
GM calls the 2.2 in 2006 HHR Gen I L61, and 2007 HHR Gen II L61.
I have do idea how different they are (only aware of a few differences,) nor why the chose to use the same RPO code for two different motors, but best not to assume similarities that may not exist in this case.
Old Feb 16, 2024 | 03:46 PM
I’ve swapped them , just used the 2006 electrical sensors and ignition. One is still driving 11 years later.
Old Feb 17, 2024 | 08:06 AM
The main difference is in the casting method.
Old Feb 18, 2024 | 12:00 PM
That's good to know. Which sensors, exactly?
Old Feb 18, 2024 | 12:45 PM
I reused the crank and cam sensors oil pressure, knock sensor.
most important the coil pack must be used from the 2006.
if the 2006 didn’t have cam sensors but the 2007 did, you have to leave them in place due to oil leaks.
Old Feb 18, 2024 | 03:41 PM
2006 2.2L does not have cam position sensors, the 2006 2.4L does have them.
Old Feb 18, 2024 | 04:35 PM
But in the 2007 2.2 , they do have them so just leave it in the head and don’t look for wires going to it.
