Can't Link with ECM
Old Jun 8, 2009 | 05:59 AM
Geoff's Avatar
Can't Link with ECM
Anyone having this problem? We tried to hook HPTuners up to tune the car and it will not communicate with the computer. I also tried to hook up the scan tool to try yo retrieve the code in the computer, it has an error.
What is going on?
Old Jun 8, 2009 | 06:04 AM
ChevyMgr's Avatar
Blown fuse maybe. I think the same fuse for the accessory outlet runs the data link.
Old Jun 8, 2009 | 08:07 AM
JoeR's Avatar
ChevyMgr is right about the power source. Check that.
Also, make sure you have a current copy of the software. That could be the issue if the power is not.
Old Jun 8, 2009 | 07:05 PM
Geoff's Avatar
Would it be one of the big fuses under the hood of the car? The Acc. works to run everything.
Thanks for the reply's
Old Jun 9, 2009 | 08:28 AM
ChevyMgr's Avatar
Check the #29 fuse under the hood. It's a 20 amp fuse. If it's not that you possibly have a wiring issue or issue with your scanner.
Old Jun 9, 2009 | 09:21 AM
JoeR's Avatar
Again, what ChevyMgr said....
#29 is for the dash outlet (cigarette lighter for some). That also powers the OBD plug.
Brad, my fuse '06 2LT is a 15. Did that change?
Geoff, If it turns out the power is not the issue, PM me. There's a data buss incompatibility that comes up occasionally with HPTuners that I know a "fix" for.
Old Jun 9, 2009 | 10:08 AM
ChevyMgr's Avatar
Yes, the 2006 shows to be a 15 amp, but doesn't tell me the fuse location number. It states it is the "Lighter Fuse".
Old Jun 9, 2009 | 06:59 PM
Geoff's Avatar
ok thanks guys, i will check it out tomorrow
Old Jun 10, 2009 | 08:25 AM
Geoff's Avatar
I checked all the fuses under the hood and inside the cabin, No blown fuse from what i could tell.
HHRSSouth
Sep 9, 2009 11:28 AM
camaro98z28
2.0L Performance Tech
Sep 5, 2009 03:47 PM
bunny
Mar 19, 2009 10:16 AM
SpicyAngelBaby
North Pacific
0
Mar 27, 2007 08:32 AM
Lee3333
Jun 10, 2006 02:05 PM
