car slips into nuetral while driving
Old Aug 15, 2016 | 02:09 PM
ENASNI TILLER's Avatar
My wife's 2008 hhr slipped into neutral (not physically in neutral but acted like it was, auto trans) for a few seconds the other day. She said it would just rev and not attempt to move along with the power steering light and flickering dash lights. It only lasted a few seconds the 2 times it did it. I checked the alternator and load tested the battery they both seemed fine. It was charging at just over 14v and the battery was just over 12 with the car off. Any other ideas? I was thinking it may be a intermittent problem with the alternator?
Any help would be appreciated. It goes into the shop on Friday unless I can figure it out before then.
Old Aug 15, 2016 | 02:26 PM
My guess is either the hot wire attachment to the fuse box or the fuse box halves coming loose or a loose ground.
Has the ignition recall been done?
This youtube will give an idea.
Old Aug 15, 2016 | 02:37 PM
Also check the ground wires just down to the right of the oil filter cap, on the transmission.
Old Aug 15, 2016 | 02:46 PM
2006 Chevy HHR Dash Gauges and Dash Lights Intermittent Issues - YouTube
The ignition recall has not been done. It seems nice and tight with no play.
Old Aug 15, 2016 | 02:47 PM
Hopefully the rain stops by tomorrow. I'll give it a shot!
Old Aug 15, 2016 | 03:27 PM
Your description is WHY a there is recall.
Old Aug 15, 2016 | 05:08 PM
The ignition switch recall can make the transmission disengage and dash lights to flicker?
Old Aug 15, 2016 | 07:03 PM
I am assuming that your wife's description is like my wife's. The ignition switch can momentarily turn the engine off making it seem that stomping on the gas is not making the car move. That is specifically the ignition recall. The Power Steering recall relates to the power steering up and turning off.
Both recalls are real and dangerous. People have died.
wbramer
Mar 11, 2019 03:13 PM
collinsrhp
Dec 29, 2017 01:10 AM
crresind
Feb 13, 2013 11:46 AM
NYBLKBEAUTY
Feb 29, 2008 09:57 PM
HillsdaleHHR
Apr 1, 2007 12:02 PM
