Car stuck in limp mode won't crank or start
I have a 2006 Chevy HHR well today the pin at the shifter on transmission broke so I un hooked the battery unhooked the ECM unbolted the fuse box and moved it out of my way fixed the pin put everything back together tryed to start it and nothing but a clicking noise from dash and my info board on gages say reduced power what is going on what could I've done
You took the fuse block apart, there's a lot that could have gone wrong. The bolts need to be tightened past the point where you think they are tight. Under the flip cover on the side(should be red) there should be a cable going directly to battery positive, and a second cable going to the starter.
terrycon
Aug 8, 2016 08:52 AM
ATLsilverSS
7
Mar 21, 2012 07:06 PM
