Cel po496
Cel po496
Hi started new thread for my CEL. First got " Check Gas Cap" Message. I cleaned the filler tube surface and replaced gas cap with new one. A couple days later got message again with CEL. Code PO496. Replaced Evap Solenoid under hood and cleared codes with scan tool. Went 4 days and got gas cap message again with CEL. Code now is PO455. Which is a EVAP leak. Any help would be appreciated Thanks
'09 SS, Auto, 100K miles
As shown in here
https://www.obd-codes.com/p0455
inspect the EVAP tube mine leaked fumes at a rusted section of the vapour tube just inside the insulation by the drivers side ( that would be the left side) rear tire. Small pin holes developed in the line.
As shown in here
The line will rot at the back . Take off any foam you see around the steel line, clean and inspect.
You could go to the front of the line and blow low pressure air in it and spray the line with soapy water. Bubbles? There's your leak
Check the canister area under the rear of the SS, have changed the fuel cap ?
