Changed Temp Sensor and Thermostat
Old Aug 8, 2022 | 10:20 PM
roadhog83's Avatar
I still have a flatlined coolant temp after changing both the thermostat and the temp sensor. I havent read code and its still there. Do i need to clear code before temp sensor works again? I thought if I went ahead and changed both out it would be sure to fix the issue with no temp reading and no AC
08 HHR LS 2.2
Old Aug 9, 2022 | 03:19 AM
roadhog83's Avatar
I actually drove it around and it started working. hoping for good
Old Aug 9, 2022 | 06:24 AM
Welcome to the site. Burp the coolant, you should be fine!
You did install an AC Delco 131-158 thermostat, didn’t you?
https://www.chevyhhr.net/forums/how-...-system-60614/
Old Aug 9, 2022 | 07:54 AM
the test does not runn until the temp rises. Ergo, the have to drive for a few minutes.
The test is a timeline of how long it takes to get to 158F.
Old Aug 9, 2022 | 08:35 AM
Don, how quickly should it reach 158F?
Old Aug 9, 2022 | 09:37 AM
I don't know, there is an AlGoreithm. Mine always does within 5 minutes.
quick66ss1
Oct 24, 2015 08:42 PM
lw9090
Oct 5, 2015 01:21 PM
SwaintaN
May 31, 2013 01:10 PM
Telepsychic
Jan 11, 2011 05:21 PM
EricHHR
Sep 30, 2010 02:32 AM
