Oil change
Old Aug 7, 2022 | 11:33 AM
Aj1968's Avatar
Oil change
I know that it was probably already asked. But I just changed the oil in my 2007 Chevy HHR 2.2l and refilled the system but it barely reads on the dipstick. What gives?
Old Aug 7, 2022 | 12:23 PM
Let it settle after you turn off the engine, is the car on level surface? It’s most likely just from the oil not back down in the sump.
these take 5 quarts with a new filter
Old Aug 7, 2022 | 06:47 PM
Any thing between the marks is good. Fluid specs are in your Owner Manual..
Look at my sig if you don't have one.
Old Aug 7, 2022 | 07:15 PM
Did the drain plug go back in nice and smooth? 18 lbs ft.
Old Aug 9, 2022 | 08:17 PM
New filter & change, will take a few to drain down for accurate read.
Book says 5 qts, mine is overfull on that, I only add 4.7 qts & is perfect..
acpantera
29
Apr 1, 2012 09:03 PM
MaryJane
Maintenance and Upkeep
63
May 14, 2011 12:04 AM
MikeX
Sep 21, 2009 05:23 PM
DdAMaN21
Oct 6, 2006 11:25 AM
KNEZRYD
Jul 19, 2006 10:42 AM
