Changed transmission
Old Mar 23, 2012 | 06:26 PM
American & Proud's Avatar
Rest In Peace
Was it said?
You DO have the Hood Fully CLOSED right?
Old Mar 23, 2012 | 06:27 PM
gom0626's Avatar
Question. Does the vehicle anti theft system light usually come on when you open the door or before you turn the key? I can't remember, and my light is on right now.
Old Mar 23, 2012 | 06:28 PM
gom0626's Avatar
Yes, the hood is fully closed
Old Mar 23, 2012 | 06:36 PM
I don't know on a 2006, check your Owner Manual. That could be the problem. The Owner Manual is available on this forum.
Old Mar 23, 2012 | 06:37 PM
VinceP's Avatar
It seems that every time we stick the key in the ignition and push it to the crank position, all the power to the car seems to die. When we stop cranking, the lights and radio come back on.
This statement here makes me think it is a battery issue of some kind. Have you checked to see if the battery has enough voltage and/or the connections? Dont want to take anything for granted.
Old Mar 23, 2012 | 06:53 PM
  #26
Have that battery load tested, and check all the wiring again.
Old Mar 23, 2012 | 07:12 PM
  #27
tim75901's Avatar
I had the same problem on a chevy cavalier. The ground wire wasn't making a good contact.
Old Mar 23, 2012 | 11:55 PM
  #28
IgottaWoody's Avatar
might also want to disconnet battery and "reset" things.....just a thought
Old Mar 24, 2012 | 08:02 AM
  #29
db/sb's Avatar
That was done...mentioned in post #1.
Old Mar 24, 2012 | 02:35 PM
  #30
We are all assUmeing that the OP does know that the battery is in the trunk. Stranger things have happened. No condescending implied.
