Chasing Codes P102, P0420, P0171 in a 2011 HHR LS
Old Jan 22, 2026 | 04:26 PM
ellist's Avatar
Thanks for the photo OldBlue!!!!!! I'll pull that heatshield and have a look at the exhaust manifold.
Old Jan 22, 2026 | 08:24 PM
If you cleared codes or disconnected the battery the OBD testing starts as if the car just came out of the factory, no CEL until the tests run.. That can take 10 cold starts or more.
Old Jan 26, 2026 | 08:44 PM
PulpFriction's Avatar
Originally Posted by ellist
That MAF sensor only goes in one way so the direction is good. I cranked down on the 2 screws pretty good but will double check.
If you don't find The battery at at least 12.5 volts in the morning before starting and it's an old battery, I would just replace it.
You need to check the stored ethanol % in the ECM. Not all inexpensive code readers will show it. It's usually buried in the menu system, can be hard to find.
Old Feb 27, 2026 | 10:15 AM
ellist's Avatar
Hi fellas and thanks much for taking the time to respond for my call for help. After checking off all the boxes the codes remained. No crack in the manifold. Battery is good and the alternator is humming along putting out 14.8V. Oh yeah, I also replaced the upstream O2 sensor. Results were the same codes.
I surrendered and took the car to a trusted mechanic and gave him a list of the work I performed and parts replaced. Even gave him receipts so he could feel comfortable about the quality of parts installed. He had it ready to go the next day! Problem was bad wires. Both the plugs that go into the MAF sensor and the TB had to be rewired. He said tracing the problem took a little time but the fix was easy. The car is clean, green and good to go. Mileage also increased dramatically.
Again, thank you for taking the time to respond. Your insights were useful and informative.
Old Feb 27, 2026 | 04:29 PM
It’s our mission to keep as many HHRs on the road as possible!
keep it clean and drive it often!
rickymoo
2.2L Performance Tech
18
Feb 10, 2024 11:56 AM
firas
Oct 18, 2021 03:27 PM
Fire_Wessle
20
Mar 22, 2021 07:32 AM
Raduque
Jul 23, 2020 08:56 PM
mijoguero
10
Jun 21, 2014 11:48 PM
