Codes opel corsa e
Old Oct 18, 2021 | 09:35 AM
firas's Avatar
Codes opel corsa e
Help with thus codes
P0133
p0102
p1133
i replaced the maf and didnt solve the problem
any ideas?
Old Oct 18, 2021 | 09:44 AM
Welcome, but this website is for the 2006-2011 Chevrolet HHR. Not even sure what a 2015 opel corsa e is.
You would be better off to find a website that deals with your type of car.
Old Oct 18, 2021 | 12:45 PM
P0133 and P1133 both have to do with o2 sensors. If it was an HHR I would suspect the fuse marked EXH in the underhood fuse box.
Old Oct 18, 2021 | 01:14 PM
P0102 pertains to MAF sensor problems
https://www.obd-codes.com/p0102
P0133 pertains to O2 sensor and pods exhaust leak, but also a dirty MAF
https://www.obd-codes.com/p0133
P1133 pertains to a possibility of a vacuum leak, faulty O2 sensor wiring
https://www.engine-codes.com/p1133_chevrolet.html
I suggest you check the MAF sensor first , make sure it’s plugged in!
Look at the exhaust if there’s a flex pipe just between the exhaust manifold and the 1st O2 sensor look for a leak there.
Old Oct 18, 2021 | 02:10 PM
I should have explained; All three codes relate to voltage problems and coincidently the MAF is on the same fuse as the O2 sensors.
Old Oct 18, 2021 | 03:27 PM
It code be a fuse, loose wire, bent pin in MAF connector or O2 connector
2 boom
Sep 22, 2017 08:16 AM
iluvmud
Sep 9, 2016 08:16 PM
stanvalp
Feb 27, 2011 09:29 PM
fasterbbc
Jan 14, 2010 06:25 PM
