miss fire codes
Old Jan 11, 2010 | 02:24 PM
fasterbbc's Avatar
miss fire codes
Anyone else having miss-fire codes? My SS will throw a code after sitting for a few days in the cold/moist winter air. Anyone else??? Dealer hasn't a clue.
Old Jan 11, 2010 | 03:24 PM
ChevyMgr's Avatar
What code(s)?
Old Jan 11, 2010 | 05:49 PM
fasterbbc's Avatar
Sorry the codes are P0300 and P0303
Old Jan 13, 2010 | 05:23 PM
BLUEHHRSS5SPEED's Avatar
Yah mine is too, I am getting p0302, two separate instances now. Only on start up, seems to run fine after. We warm ours up first before we take off and have never noticed a missfire. I erase the codes and no problems after. We have 25,000kms on ours.
Old Jan 13, 2010 | 05:40 PM
ChevyMgr's Avatar
Any powertrain or induction mods?
Old Jan 13, 2010 | 09:42 PM
fasterbbc's Avatar
my HHR is 100% stock. the code only comes up as you said on start up. it never misses a beat otherwise. can't say I even noticed a stumble when it set the code. I always let it warm up at least 5 minutes before it moves. I have seen one service bulletin that is relative to moisture in the spark plug well, but the engineer was still collecting data. did this ever get a fix???
Old Jan 14, 2010 | 02:58 PM
My HHR has the gm stage 1 upgrade. As for anything else I have a autostart remote start in it with a idata bypass. I already eliminated the remote start as the problem by disconnecting it for a couple weeks, then it set the light on again with it disconnected.
Old Jan 14, 2010 | 06:25 PM
ChevyMgr's Avatar
The engineering TSB was closed with no clear cut solution as to why the codes were being set. They recommended that the dealer follow normal diagnostic procedures.
Waltam
May 15, 2014 08:23 AM
fasterbbc
Jul 30, 2012 09:27 AM
Rainman
10
May 10, 2010 06:37 PM
jonny4eyes
South Pacific
Apr 18, 2010 07:32 AM
FMHHR
Apr 7, 2010 01:22 PM
