Check Engine light
Check Engine light
I have an 09' auto SS and recently got the check engine light on and, I have two trouble codes the P0106 and P0107. The car runs well but sometimes I lose boost while driving. Have any of y'all encountered this problem ?.
Then it is the well documented wiring problems.
If it was an early GMPP the wires are crimped and the get corroded/broken they need to be soldered and shrink wrapped; later kits were plug and play. Also the MAP sensor has the connector backwards, so the wires hit the AC compressor and short out; it needs either a custom bracket or other modification.
Alan Mullins
2.2L Performance Tech
12
Nov 29, 2016 11:27 PM
menance
Dec 22, 2010 06:14 PM
beachbum1970
Mar 25, 2009 08:46 PM
