Checking battery voltage
Old Feb 6, 2022 | 04:42 PM
Is the Duracell the same as the Ever Start battery or a different company! I googled the Walmart site and the site doesn’t state anything about a vent tube.
Old Feb 7, 2022 | 08:05 AM
a lot of batteries come with the vent hole, only some come with the tube. I have never seen an ad that stated anything about a tube.
Old Feb 7, 2022 | 08:49 PM
I haven't either.. Guess it is just a given.. Even new Corvettes use our size & vented battery.
Old Feb 12, 2022 | 08:57 PM
WilliamKirkland's Avatar
Planning preventive Maintenace on wife's HHR. It's an 06 on its second battery per owner's papers I got when bought. I think it's 5+ yrs old. Local auto parts store said best bet is go to dealer get AC Delco ..prepare to get hosed. Store doesn't do HHRs as battery special order and they don't accept payment for installing Auto Zone batteries and it's not a quick job. Nothing on a HHR is ever simple. Wife switched to garage near work..got 4 plugs plus install...charged $12.95 for plugs ..job was over $150..normal? ps They bent the brace wrestling the air cleaner back on and posts would't line up; check engine light came on.. Did jpob myself, but 40 minutes later after reinstalling air filter gizmo, lights went off. pulled bent bracket fwd at least an inch!!
Old Feb 12, 2022 | 09:09 PM
The battery is an easy job. Fold the rear seats down, put the cargo shelf on the folded down seats. Unscrew the big round wingnut and put the spare tire cover on top of the cargo shelf.
Remove the negative battery cable and secure it out of the way. Remove the positive battery cable, then loosen the 2 clamping blocks.
Remove battery.
Installation is reverse.
Old Feb 12, 2022 | 09:24 PM
  #26
Yep & Auto Parts only do not want to install. But they will sell ya a battery.. Mine #2 is from there, over 4 years IIRC .. Simple install once you get familiar with the deal..
Allegretto
Sep 4, 2020 08:28 AM
john11
Aug 28, 2020 07:26 PM
Cat Man HHR
May 26, 2019 09:00 AM
riceman
Jul 4, 2015 06:02 PM
jeff schaffer
2.2L Performance Tech
Sep 8, 2013 01:50 AM
