Chevy hh
hhr wont start... I have a 2010 hhr.. Getting fire and fuel.. Won't start.. When trying to start the car should the butterfly in the throttle body open all the way open if u press the accelerator to the floor ??
Welcome to the site, first lets start with some background info:
- what engine is it - 2.0, 2.2 or 2.4?
- how many miles so far?
- if the Check Engine Light is on, what are the downloaded error codes?
- what was done to it just prior to it not starting?
- did you recently clean the throttle body? and if so, did you move the butterfly manually?
- how can you see the butterfly with the rubber bellows from the air filter attached? (it needs the MAF sensor in place for proper operation)
