Clunking issue: Solved!
Yes, I know I'm resurrecting an old thread but couldn't find the answer on it. I had the sway bar links (the vertical rod) replaced, but the clunk has come back on the right side, started when I went over a bump. Got under there and found that the bottom nut was not tight. I put a wrench on it and it seemed to turn too easy, felt like it wasn't tightening, but wasn't sure if its supposed be that way, or should it be nice and tight????
2009 hhr clunking noise
I have had the left control arm replaced ( right was done 2 yrs ago) and I had the sway bar bushings done. I still have the noise and the mechanic says it’s safe to drive. I just don’t know what to do!
Have the mechanic check the sway bar LINKS - they seem to wear out fairly quickly. If your mechanic you are currently using can't find the source of the clunking, find another mechanic.
How many miles on the HHR?
Could it be the bumper cover or the air box bracket or the fender liners or any of the plastic bits held on with plastic rivets?
Dont think so.
