Clutch rattle
Old Jun 6, 2013 | 10:51 PM
ecpff's Avatar
Clutch rattle
28,000 miles on the clock. For the last week when I let the clutch out at low speeds I get a stuttering vibration and a shaky rattling sound from the clutch area. Other than that the tranny shifts well and the clutch operates fine. Any one experience this issue?
Old Jun 6, 2013 | 11:12 PM
LawDog88's Avatar
Silly question, but you are giving it some gas as you let off, right?
Old Jun 6, 2013 | 11:17 PM
ecpff's Avatar
I'm driving it the exact same way I've driven it since new. This vibration/sound has just started happening. I'm going to take it to dealership early next week and see what they say.
Old Jun 7, 2013 | 08:51 PM
Have you thought about taking it to the dealership to have it checked out?
Jessica L.
Chevrolet Customer Care
Old Jun 7, 2013 | 10:41 PM
ecpff's Avatar
Yes, we are probably going to have it checked out on Tuesday.
Old Jun 8, 2013 | 12:43 AM
Sounds like the more often used term "clutch chatter" when letting it out.
The clutch disc has springs under pressure in the disc itself. If they lose pressure it can chatter.
Or if you get some hot spots on flywheel & pressure plate.. Another possible is a partially collapsing pressure plate.
Old Jun 8, 2013 | 10:14 PM
B.Diggity's Avatar
Or in my case too thin of the fluid.
I have dex6, where as before my clutch swap, maxlife atf. Will be switching back soon.
Had no problems before swappin fluids though.
Old Jun 8, 2013 | 11:21 PM
?? You have a rattle or chatter from too thin of trans earl ??
Old Jun 8, 2013 | 11:42 PM
LawDog88's Avatar
I believe earl was referring to the tranny fluid.
Old Oct 3, 2013 | 08:54 PM
ecpff's Avatar
Just to follow up. Finally had an opportunity to have this rattle checked out. The cause ended up being a broken rear air cleaner bracket. Replaced at no charge under bumper to bumper warranty.
