code P0451
Old Feb 27, 2012 | 12:27 PM
07 chevy hhr's Avatar
code P0451
Hi I have a 2007 Chevy HHR LS Panel with around 50,000 miles, recently the check engine light came on and I was able to pull code P0451 (EVAP Emission Control System Pres Sensor Range) with a scanner. I have not noticed any problems while driving, can anyone guide me on what I need to check on the vehicle?
Old Feb 27, 2012 | 12:38 PM
Ratracer's Avatar
The gas cap. You'll get that if it's loose.
Old Feb 27, 2012 | 01:44 PM
to the forum 07 chevy hhr!
Yeah that's the "loose cap" code, they either didn't tighten it until it clicked when you filled up last or you have a cap going bad.
Check the O-ring on the cap for cracking or breaks, if it looks OK, tighten it until you hear the required number of clicks and the code should clear itself after some driving.
If your cap is pooped out, Stant part number 10841 is the $10 replacement available at any auto parts store.
NxlKing2304
Feb 14, 2014 07:41 AM
RPetersen14
Oct 25, 2013 11:19 PM
edgarfrog
Oct 25, 2013 08:43 AM
LtGhost08
Jun 10, 2013 02:13 PM
tntwolt
Jul 27, 2011 05:53 PM
