code u0073
Old Aug 1, 2017 | 10:47 AM
Cat Man HHR's Avatar
Originally Posted by donbrew
It does have CAN, It is just not the same programming, and the fact that guys fixed itself lends credence to the loose connection theory.
So are you saying the loose connection points to the BCM being that it was reset by the R&R of his 25 amp fuse ?
Old Nov 4, 2017 | 04:50 PM
I just wanted to update this "problem".
Again, the no start only seemed to be when internal cabin temps got high with the windows closed.
I happened to do front brakes and kept the key on to unlock the steering as I turned the wheels to work on the job. After the repair, which took a little over
an hour, the battery was dead.
The battery was an AC/Delco of unknown date. Could have been original (2010).
Install a Interstate battery and have not had the problem again so far, when day's were hot to cause the problem.
Yeah, I know "Stranger than science"
Old Nov 4, 2017 | 05:55 PM
A brand new battery will not hold up for a brake job. Ask how I know.
Old Nov 4, 2017 | 07:38 PM
I didn't know the brakes and interior door locks were inter-related - I was barely able to start it after swapping interior door handles around. I guess a brake job takes more power?
katarn
Jul 8, 2015 06:11 AM
cj krause
Feb 22, 2014 01:39 PM
edgarfrog
Oct 25, 2013 08:43 AM
LtGhost08
Jun 10, 2013 02:13 PM
JACK VICTOR
Mar 4, 2012 11:10 PM
