coding replacement ignition cylinder
Old Jul 2, 2012 | 12:54 PM
garsplace's Avatar
Does anyone have instructions on setting the tumblers in the replacement ignition cylinder that is bought from the dealer? I was told to take the old one apart and use the same numbers that are on it, however once you remove the retainer pins from the factory ignition, they will not go back in,and I also read that you have to pay an additional 100-150 bucks to get the dealer to re-code it for you
Old Jul 2, 2012 | 06:00 PM
By re-coding, do you mean setting the pins to fit the old key? Or setting the key security code.
It is my understanding that it is the key to steering column relationship, not key to ignition cylinder. Somebody else will no doubt come in with a lucid answer.
Old Jul 2, 2012 | 06:53 PM
ChevyMgr's Avatar
You are probably under the recall or special policy on this issue. PM me the last 8 of your VIN and I can tell you.
alexrckid
GM Recall Campaigns
Apr 9, 2014 09:21 PM
sbrice54
Aug 21, 2013 09:31 AM
Putter
Jul 31, 2013 09:12 PM
10RedSS
Jan 13, 2012 07:10 AM
richie6
Jan 13, 2009 10:34 AM
