Computer Inside HHR not Working
Old Dec 9, 2014 | 02:31 PM
juanitamelson01@gmail.com's Avatar
Question Computer Inside HHR not Working
Advanced Auto tried to read the codes but said my computer was not working and I would have to have it checked under the hood has anyone had this issue.
Old Dec 9, 2014 | 02:59 PM
Welcome to the site, yes have your battery checked, a weak battery or loose wires can be the cause
Old Dec 9, 2014 | 03:20 PM
db/sb's Avatar
Could be that under-hood fuse # 29 is blown. Really don't know what he meant about having to have it checked under the hood.
Old Dec 9, 2014 | 04:17 PM
x2 - check that fuse already mentioned. The cigarette lighter uses the same fuse so you can verify as well by checking the power receptacle.
And why would you ever use your email address as a name on a forum or post it openly on the web? Do you not realize that it is an open invite to spam that would render your mailbox useless. To change your name, you will have to contact 843de, our Administrator.
Old Dec 9, 2014 | 05:10 PM
db/sb's Avatar
gmail addresses are pretty much throw away addresses.....
Old Dec 9, 2014 | 07:52 PM
Not necessarily - a lot of people depend on them. Regardless, having it openly posted is not a good thing.
Old Dec 9, 2014 | 08:27 PM
Lucky's Avatar
Welcome to the site
if all fuses check out don't be afraid of letting a different store check codes.
Parts guys are normally not tech's and sometimes it's just user error.
Old Dec 10, 2014 | 06:22 AM
db/sb's Avatar
What I meant is that they are easily changed and not dependent on your ISP.
Marush
Jan 27, 2015 12:08 PM
mgeinitz
Jan 30, 2014 05:42 PM
JCJSS
Nov 3, 2013 06:21 PM
tracy waddell
South Pacific
Feb 9, 2011 12:53 AM
