Condensation in oil fill cap
Old Jan 16, 2023 | 08:56 AM
flstss's Avatar
I noticed some condensation when I took the oil cap off.
I changed the oil in the oil looks fine coming out. Is this a common thing? I've never noticed it before. It's clear like clean water just a few drops up there. Thanks
Old Jan 16, 2023 | 09:35 AM
If it is water it shouldn't be a problem. It could be worrisome if it is white foam indicating water in oil.
Old Jan 16, 2023 | 12:25 PM
Just condensation, but keep an eye on it.
Old Jan 16, 2023 | 01:21 PM
greg8453's Avatar
Don't let it bother you. When the engine goes from hot to cold moisture accumulates in areas.
Old Jan 16, 2023 | 06:58 PM
flstss's Avatar
Yeah I know that I've seen that before, but the last time I changed the oil it came out as always. Just a little darker than when I put it in. I use mobile ones synthetic
Old Jan 17, 2023 | 12:15 AM
Bonez's Avatar
Its normal in cold weather... Find someone with a Dodge ram or Dakota that has the 4.7L and look in their oil fil tube/cap.... looks like thick yellow baby poo. I freaked the first time I seen mine do that years ago.
haX0r
Maintenance and Upkeep
Sep 3, 2021 05:20 PM
guppy
Dec 5, 2016 07:31 AM
hhrlover101
Oct 25, 2013 12:38 PM
WYWendinger
2.4L Performance Tech
13
Aug 9, 2013 09:50 PM
AJochum
Oct 17, 2009 03:28 PM
