Coolant level dropped in the reservoir
Old Nov 6, 2016 | 04:16 PM
slonny's Avatar
Originally Posted by aradmahogany
I was at the point of checking every other day after I had a ghost leak that turned out to be the pressure cap. Replaced about 7 months ago and no change in coolant level since. If you do have a leak start at the top and work your way down! Mine just happened to be the cap so I got lucky.
That is exactly where the coolant is leaking. The coolant level kept on dropping so I reinspected it again and noticed that there is some fluid around the pressure cap. I decided to top off the fluid and give the cap a good twist hopping that it will solve the problem. Several weeks later the same story.
Is this a good choice? https://www.amazon.com/ACDelco-RC85-.../dp/B000C9S78G
Old Nov 6, 2016 | 05:17 PM
yes
Old Nov 7, 2016 | 06:30 AM
aradmahogany's Avatar
Funny thing; mine only started leaking after I had gotten the coolant system serviced (Flush and fill) just like yours. Mine wasn't as significant as yours and I had to actually chase it by scent. Still no leaks whatsoever to this date!
RJ_RS_SS_350
Maintenance and Upkeep
Apr 5, 2018 10:03 PM
mojoman
Dec 23, 2013 06:38 PM
08LaRam
Aug 3, 2013 07:00 PM
REDHHRSS
Jun 3, 2009 09:24 PM
denny
Dec 26, 2006 09:04 PM
