coolant or oil sludge in air intake?
Old Sep 24, 2016 | 06:39 PM
Blue_SS's Avatar
But his name was Stark; how could you question ? Watch for Iron Man in your neighborhood soon.
Old Sep 24, 2016 | 06:57 PM
Sorry for the lousy video, I should have previewed it
Old Sep 25, 2016 | 06:31 PM
littlehoov's Avatar
Well I havent had a change to do a compression test yet. I did take the time to pull the spark plugs today just to have a look.
Here is a picture of the plugs, they are in order left to right taken out of the engine.
They actually all look about the same, even though the picture makes the one on the left look worse.
Anyone have an opinion?
Also, if a compression test doesnt reveal anything bad, is the leak down test still necessary?
Old Sep 25, 2016 | 07:34 PM
Looks like you need new plugs, the center electrode is gone, worn out. Those are probably original plugs. Not sure what the grey residue is. Is it ash-like deposits? Of course, it doesn't explain your coolant loss.
Old Sep 25, 2016 | 07:48 PM
The one on the left might explain it; it looks steam cleaned from here.
Grey residue usually means lean, could be due to the horribly worn out plugs.
Those plugs have been bad for a long time.
Old Sep 26, 2016 | 07:54 AM
littlehoov's Avatar
Yes it is a gray, ashy textured deposit. Very hard and cooked on. I plan on replacing the plugs this evening and hopefully doing a compression test if the tool is available to rent. The plug on the left doesn't look much different in person, the picture just makes it look that way. I'm planning on getting Ac Delco 41-105 plugs is that right for an 06 with 2.2?
Old Sep 26, 2016 | 08:04 AM
Those are the plugs for your 06
Old Sep 26, 2016 | 08:15 AM
You will be amazed how worn out your old ones are compared to the new.
DO NOT ATTEMPT TO GAP THE NEW PLUGS. They are pre gapped in the box.
Old Sep 26, 2016 | 08:26 AM
aradmahogany's Avatar
I used the same ones. They are pregapped and have a protective sleeve for transportation. Just basically plug and play. I had no issues. Dont forget dielectric grease and do not use anti seize!!!!!!
Old Sep 26, 2016 | 01:43 PM
littlehoov's Avatar
What's the reasoning for not using anti-seize? I have always used anti seize on engines with aluminum heads. Just curious.
