Coolant temp issue
Old May 15, 2016 | 06:14 PM
When mine is started from cold, it will climb to about 205-211 as it warms up going down the road. Then the thermostat will open and the temp will drop down to 180 ish. It will then climb to about 187-189 and remain there.
I have seen mine climb up to the 205-207 range when stuck in traffic. Cools back down when I get going again and have some road air flow through the radiator.
Try a new thermostat as suggested. The climbing temps then sudden drop sounds like a sticking thermostat not opening at the correct temp.
Old May 15, 2016 | 07:45 PM
Coffan's Avatar
Seeing how there's still a 45days warranty from when I bought it in going to take it in and see what they say
Old May 15, 2016 | 08:48 PM
Don't be surprised when they stick a cheap aftermarket thermostat in and possibly even incorrect coolant! And the prerequisite air bubbles, which they're gonna blame a headgasket on!
Old May 16, 2016 | 02:15 PM
Coffan's Avatar
Well the pressure test was fine and the thermostat is fine turns out they never topped off the coolant before I bought it. And they use Dexcool so we should be good now. If I still have problems I'll be taking it back.
Old May 16, 2016 | 02:48 PM
Why would it need to be topped off? Where did it go? You mean to say you never bothered to check the level?
It doesn't take a mechanical engineer to unscrew a cap or to look at the overflow tank. I'm pretty sure the Owner Manual explains how to check the coolant level.
Old May 16, 2016 | 03:14 PM
Coffan's Avatar
I won't lie I was lazy. Plus if that isn't the problem now that I had them open a ticket for the problem if it happens again I can take it in outside my 45 day warranty and they can take care of it.
Old May 16, 2016 | 03:33 PM
I'm lazy, too. But, I spent more time here than looking at a bottle under the hood would take.
quick66ss1
Oct 24, 2015 08:42 PM
Leemor
Jun 9, 2014 06:33 AM
MikeRuth
Jun 30, 2012 11:28 PM
oms
May 20, 2011 01:54 PM
CeliaFoote
2.4L Performance Tech
Jul 30, 2009 08:20 PM
