Coolant temp problem
Old Aug 3, 2015 | 11:20 AM
lw9090's Avatar
It is an ACDelco 180 OEM
Amazon.com: ACDelco 131-158 GM Original Equipment Engine Coolant Thermostat: Automotive Amazon.com: ACDelco 131-158 GM Original Equipment Engine Coolant Thermostat: Automotive
Old Aug 3, 2015 | 12:01 PM
Well, the one you have is stuck open or the temp sensor is defective. I can't think of any other reason it would run too cold. Maybe an air bubble fooling the sensor.
Topping out at 160F is pretty low, mine would run 172F when it was stuck.
Old Aug 3, 2015 | 12:38 PM
lw9090's Avatar
I just went out to lunch and the temperature started registering again and stayed between 180-193. How do I check and get rid of an air bubble?
Old Aug 3, 2015 | 07:49 PM
Park the HHR with the front end higher than the rear, let the HHR cool off then remove the pressure cap and check the coolant level and top up if required.
Old Aug 8, 2015 | 11:18 AM
Rzrman328's Avatar
First post but been lurking around...
Same issue as original poster....first time, replaced tstat with a Napa tstat. Ran anywhere from 168-171 degrees. That worked for about a week until the ---f came back. Then today, I replaced my tstat with acdelco and my temp gauge/ ac is working again. It is now running anywhere from 183-189 degrees. My concern is that my CEL never came on at all, ever. Is that something else I should be concerned about or maybe it's just one of those electrical gremlins? Thx.
Old Aug 8, 2015 | 11:57 AM
Well there is a lot of info here about coolant temps. Here are some highlights:
A. Above 180F is "normal"
B. Below 180F is BAD
C. Assuming the code you got was P0128, the problem is the coolant did not warm up to 180F fast enough. The CEL does not always come on.
D. The t-stats job is to get the temp UP, not down.
Old Aug 22, 2015 | 12:57 PM
Rzrman328's Avatar
Ok I'm back again....
So I put a GM thermostat in the car...it ran good, no issues everything working fine for a couple weeks. Temps were fluctuating between 195-204 normally driving so I thought it was fixed.
Yesterday I get the "---" again. And no a/c.
Temp sensor? Ecu? Any suggestions thx.
Old Aug 22, 2015 | 01:18 PM
Usually that means too cool, or the ECU thinks it is.
Easiest thing is to pop the T-stat out and inspect it, next would be the sending unit. ECUs don't normally break.
Old Aug 22, 2015 | 01:23 PM
Rzrman328's Avatar
Before I pull the tstat out (again) you think it would be bad? I just got it brand new.
The ac delco did work better than the Napa tstat as the Napa tstat never registered temp over like 180.
Old Aug 22, 2015 | 01:27 PM
Could be defective or they gave you the old design or some other piece of junk floating around the coolant. You have to take it out to get to the sensor anyway.
