cranks but no start
Old Feb 4, 2023 | 04:30 PM
WillH's Avatar
cranks but no start
I have been lurking for a bit, but looks like a have a bad reason to join and post.
My wife was driving her HHR the other day, got about 5 miles from home and it died. We pulled it back home with the Suburban.
The starter would run, but it would not crank the engine. I figured the starter was bad, so I replaced it. It still will not crank or start. It's not loose, the Bendix Gear is not skipping across or off the flywheel. I checked the relays, checked any codes with a scan tool (grasping now, I know) and cannot find anything. The battery is fine. It simply spins but will not engage with the engine. I am out of ideas. Anyone got any good ones before I tow it to a shop in shameful defeat?
Oh, I forgot. It's a 2011 automatic with 75xxx miles.
Old Feb 4, 2023 | 07:30 PM
Hi Will, to the forums!
Maybe it's turning the crankshaft only. The timing chain may have broken. Remove the valve cover and have a look. Do not crank the engine over anymore! Hopefully, catastrophic damage has not already happened.
Timing chain issues are usually preceded by a check engine light. Many people tend to ignore the CEL, a very bad idea!
Old Feb 4, 2023 | 08:11 PM
greg8453's Avatar
See if you can turn it at the crank pulley.
Old Feb 4, 2023 | 09:54 PM
WillH's Avatar
I was going to do this today, but the pulley does not match up with the hole in the wheel well. I can see it, but it is about 1/2" too low to get a socket on.
Old Feb 4, 2023 | 09:55 PM
WillH's Avatar
While it is spinning the starter also seems to be slow. I will check the wires going to it for voltage drop in the morning. I have read a few things about that on here and I am wondering if it is turning too slow to throw out the Bendix Gear.
Old Feb 5, 2023 | 07:49 AM
To get to the harmonic balancer bolt(21mm) you have to remove plastic splash shield
Old Feb 5, 2023 | 08:13 AM
WillH's Avatar
Ah, thanks. The bolt I saw did seem a bit too far forward. Sorry, this is my first experience with this vehicle.
Old Feb 5, 2023 | 08:24 AM
That bolt is the serpentine belt tensioner a 15 mm . If it’s low in the oblong hole, the upper engine mount needs to be replaced
Old Feb 5, 2023 | 08:40 AM
WillH's Avatar
I will look into that once this is solved. Thanks. This engine has already been more trouble than my 08 Cobalt. I had it for 10 years and 265,000 miles with never a day of trouble until my younger brother tried to wrap it around a tree. Nobody hurt, except my car.
Old Feb 5, 2023 | 09:24 AM
Yikes, I hope he walked away from that one. Nasty impact damage
