Crankshaft seal question
Old Oct 29, 2021 | 12:11 PM
littlehoov's Avatar
Hey all, I will be tackling a leaking front crankshaft seal soon, thanks in large part to posts on this forum for making it easier.
I do have a newb question though, which direction does the new seal face when installed?
The new seal has a plastic protective cover on it if that helps as a reference.
Old Oct 29, 2021 | 04:36 PM
The protector is on the outside of the seal, just pry out the old seal and tap in the new seal with that protective piece in place .
Old Oct 29, 2021 | 09:47 PM
littlehoov's Avatar
Ah! That makes a lot of sense actually. Thank you!
Old Oct 30, 2021 | 07:09 AM
You’re welcome. I use a piece of 1 1/2 inch plumbing pipe to install the seal into the front cover.
Gearhead1
Jun 25, 2021 04:37 AM
Krazi.Laura
Nov 6, 2020 01:02 PM
Spike421
Mar 1, 2019 02:21 PM
donbrew
Drivetrain (Excluding Engine)
Mar 18, 2012 03:51 PM
hhrdad
Jan 29, 2008 02:44 PM
