crankshaft sensor wiring
Old Sep 14, 2014 | 12:08 PM
db/sb's Avatar
That is odd. This is what mine shows in conjunction with the last attachment I posted:
Old Sep 14, 2014 | 12:14 PM
Hey Stephen. Didn't we go thru this before ? You and me having conflicting info from our repair manuals.
Not sure what to think. One side note though. My info and pic did come from a 2008 repair manual. That may be the difference.
Old Sep 14, 2014 | 05:45 PM
Sno White's Avatar
The problem is firemangeoge is showing a "block" diagram and db/sb is showing the actual part - they often show different things. In this case the colors and pin numbers jive with each other - there is no problem.
Old Sep 15, 2014 | 06:08 AM
There is a possibility that a new connector with wires is available, NAPA has many the dealer should also. Then you would just splice.
The fact that they are available should make you feel like you have company anyway.
BTW, you may have a code after you get it back together. You will need somebody with an expensive scantool to reset the CKP.
KJT
Oct 10, 2014 05:39 PM
myers1wa
Nov 10, 2013 11:26 PM
Hamadock
Aug 6, 2013 04:31 PM
rbrewer
Apr 6, 2012 01:11 AM
JBP
2.0L Performance Tech
52
Apr 14, 2008 09:29 AM
