Dash lights flickering ,no crank no start
Old Jan 20, 2024 | 07:52 AM
  #71
Rockinron's Avatar
When I take the top of the fuse box off what am I going to be looking for?
Old Jan 20, 2024 | 07:56 AM
  #72
Rockinron's Avatar
I’m going to remove the ground wire from the TCM to the strut bolt and will be buying a new key to see if the original is worn out.
Old Jan 20, 2024 | 08:22 AM
  #73
I don't know why you are focused on a worn out key. What do you think wears out and leaves it able to turn?
If the recall has not been done you can get a new key, cylinder and switch installed for free. If it has been done the ones you have are several years newer than your car.
I know that the mobile site is a bit hard to scroll; have you read all of the previous 70 posts in this thread?
Old Jan 20, 2024 | 05:31 PM
  #74
Rockinron's Avatar
Unhappy
Well I tried a new key and nothing ,While I was at the dealership I had them check for recalls,
5/08/2014, Replace Ignition Lock Cylinder ,
05/08/2014 Replace ignition and Start Switch,
08/29/2006 Bulbs Stop ,Tail and Turn lamp (Left)-Replace
Old Jan 20, 2024 | 06:45 PM
  #75
In your first post, you said you checked all fuses and relays. How did you check them? Fuses are pretty easy to test, but how did you verify that the relays were good?
Old Jan 20, 2024 | 07:10 PM
  #76
Rockinron's Avatar
Hello,
At first I just looked for broken connection and tried turning the key and felt for a click? recently I used a malti meter set it to sound and made contact with the pins negative and positive on the fuse in the fuse box, all were good,
I used a 9V Battery and went across the relay at a angle to listen for a click,
I have been rereading all the posts from page 1,and restarting from there I'm on page 41 now.
Old Jan 20, 2024 | 07:46 PM
  #77
Originally Posted by Rockinron
Hello,
Not a clue what you’re saying here. There’s not 41 pages in this thread.
Old Jan 20, 2024 | 07:50 PM
  #78
I think the mobile site shows 1 post per page or is different , anyway.
Old Jan 21, 2024 | 07:52 AM
  #79
8 pages, 79 posts.
Old Jan 21, 2024 | 09:37 AM
  #80
Rockinron's Avatar
Hello,
when I turn the key to the second position I get all dash lights and gages on after a minute the engine and brake light warning light are still on? Could there be a problem with the brakes and it’s not letting the car turn over?
