Dash lights flickering ,no crank no start
I don't know why you are focused on a worn out key. What do you think wears out and leaves it able to turn?
If the recall has not been done you can get a new key, cylinder and switch installed for free. If it has been done the ones you have are several years newer than your car.
I know that the mobile site is a bit hard to scroll; have you read all of the previous 70 posts in this thread?
Well I tried a new key and nothing ,While I was at the dealership I had them check for recalls,
5/08/2014, Replace Ignition Lock Cylinder ,
05/08/2014 Replace ignition and Start Switch,
08/29/2006 Bulbs Stop ,Tail and Turn lamp (Left)-Replace
Hello,
At first I just looked for broken connection and tried turning the key and felt for a click? recently I used a malti meter set it to sound and made contact with the pins negative and positive on the fuse in the fuse box, all were good,
I used a 9V Battery and went across the relay at a angle to listen for a click,
I have been rereading all the posts from page 1,and restarting from there I'm on page 41 now.
Hello,
when I turn the key to the second position I get all dash lights and gages on after a minute the engine and brake light warning light are still on? Could there be a problem with the brakes and it’s not letting the car turn over?
