Dead electrical and stuck key
Just talked to the Service Dept.... They told me the HHR had dead electrical system again this morning, and they had the car, but had not had a chance to run diagnostics on it yet.
I'm glad I decided to drive over last night and use the drop off service.
Anyone else had this problem with the electrical system randomly dying?
I'm leaning to the ignition switch having crapped out or a master fuse of some sort... but the random loss of electrical has me leaning more to the ignition switch. (I work with electronics every day and spend 50% of my time troubleshooting systems here)
I remember a sticky post someplace, warning to push IN all the fuses, as some were loosening and causing something like this. - ???
I don't remember the details, but after getting my Panel, I pushed them all in tight under the hood and at the front passenger side fuse block.
Look for that thread and see.
Here's the link to that thread, its always a good idea to check the underhood fuse box periodically since HHR's will vibrate them loose over time.
https://www.chevyhhr.net/forums/problems-service-repairs-42/underhood-fuses-tip-155/
