Dead electrical and stuck key
Old Mar 28, 2012 | 09:16 AM
Haunted_Hot_Rod's Avatar
Just talked to the Service Dept.... They told me the HHR had dead electrical system again this morning, and they had the car, but had not had a chance to run diagnostics on it yet.
I'm glad I decided to drive over last night and use the drop off service.
Anyone else had this problem with the electrical system randomly dying?
Old Mar 28, 2012 | 09:17 AM
Not a clue, unless when the key stuck, the ignition switch became lodged in a "halfway there" position...not fully off and not fully on, that would maybe explain it...maybe.
Old Mar 28, 2012 | 09:27 AM
A dead electrical system or dead battery? In laymans terms, the system could be dead,but the battery have a charge. In simple terms, is the power not getting from the battery to the rest of the car? If that's the issue, it sounds like a fuse,relay,ground or connection problem.
Old Mar 28, 2012 | 09:32 AM
I'm leaning to the ignition switch having crapped out or a master fuse of some sort... but the random loss of electrical has me leaning more to the ignition switch. (I work with electronics every day and spend 50% of my time troubleshooting systems here)
Old Mar 28, 2012 | 09:39 AM
American & Proud's Avatar
Rest In Peace
I remember a sticky post someplace, warning to push IN all the fuses, as some were loosening and causing something like this. - ???
I don't remember the details, but after getting my Panel, I pushed them all in tight under the hood and at the front passenger side fuse block.
Look for that thread and see.
Old Mar 28, 2012 | 09:42 AM
would have loved to... it's at dealer service already.
Old Mar 28, 2012 | 09:44 AM
Here's the link to that thread, its always a good idea to check the underhood fuse box periodically since HHR's will vibrate them loose over time.
https://www.chevyhhr.net/forums/problems-service-repairs-42/underhood-fuses-tip-155/
Old Mar 28, 2012 | 09:56 AM
Will add that to my monthly to-do calendar. Thanks
Old Mar 28, 2012 | 09:59 AM
Mr. Goodwrench will fix you right up today !!
Old Mar 28, 2012 | 10:03 AM
Pssst...Sam, they retired Mr. Goodwrench, he's off at the "Old Spokesman's Home" with the Maytag Repairman.
