Desperate for help
Old Jul 18, 2020 | 12:16 PM
Mike Fry's Avatar
Replaced the blower motor,2 days with no dripping so far,maybe the chemical did the trick,thanks for that
Old Jul 18, 2020 | 12:28 PM
Yesterday's humidity should have made a huge puddle of water under the car. Did it?
Old Jul 18, 2020 | 01:27 PM
Easy now, let’s see if the blower motor and the A/C are fully functional and the deism hose is the only point of water dripping.
Old Jul 18, 2020 | 03:11 PM
Mike Fry's Avatar
Lol that's why I said maybe,but so far no sloshing sounds,no water dripping in car,been running it all day,and it's nasty hot and humid,so far so good,keeping fingers crossed
Old Jul 18, 2020 | 05:42 PM
IS IT DRIPPING WHERE IT IS SUPPOSED TO DRIP?! Can you hear me now?
I am asking if the condensate is making a puddle under the engine compartment like it supposed to. If it is not the drain is still plugged.
Old Jul 18, 2020 | 09:16 PM
  #26
Please check the firewall behind the exhaust manifold, is water dripping out the drain hose?
That’s the hose on the passenger side of the catalytic converter
Old Jul 19, 2020 | 10:51 PM
  #27
Mike Fry's Avatar
The drain hose does drip some,not much,but tonight I had water pouring from under the glove box like someone turned on a hose,no warning by sloshing sound before,just did it,does a 09 need a butyl patch,replaces the windshield wiper transmission couple weeks ago,and I could see the hole above the cabin air filter,didn't look like there was ever one there,have had the drain hose cleaned 6 different times in 2 weeks,guess the clog must be in the evaporator pan,
Old Jul 19, 2020 | 11:24 PM
  #28
Mike Fry's Avatar
Asked about butyl patch only because it did rain hard for a bit tonight
Old Jul 20, 2020 | 06:44 AM
  #29
The 07, and later years did not require that patch, the cowl was revised
A 2006 , the patch needs to be replaced
A 2006 with the patch removed
This is a 2010, but the same as 07 thru 11 model years, note the difference in the shape of the holes.
It’s the oval shaped ^^piece
There is a drain hole in there, pull the wiper cowl cover and check it
Old Jul 20, 2020 | 11:21 AM
  #30
Mike Fry's Avatar
I appreciate all the help,sorry if I don't word things perfectly but I'm trying,there is no water dripping from under the car at all,was a little before but now nothing,ran it all morning and it's dripping inside,but not outside at all
