Desperate for help
Old Jul 20, 2020 | 12:03 PM
  #31
Sometimes the rubber tube gets disconnected from the pan.
Old Jul 20, 2020 | 02:07 PM
  #32
Mike Fry's Avatar
How would I fix it if it got disconnected from the pan,is that part of the all day taking the dash out job,or simpler than that
Old Jul 20, 2020 | 02:53 PM
  #33
Mike Fry's Avatar
It has gone from dripping to full on pouring out from under the glove box if I run it now
Old Jul 20, 2020 | 03:27 PM
  #34
Lonwane's Avatar
It sounds to me as if your drain is plugged.
To fix requires the removal of the cowl cover from inside of the engine compartment below the windshield.
This procedure also requires the removal of the windshield wiper arms (15mm nut).
Takes about 15 minutes to remove.
Clean out the drain area.
Check for proper drainage.
Reassemble.
That's what I had to do to mine.
Old Jul 20, 2020 | 04:22 PM
  #35
As shown in post #29 , you will have to take the wipers off, as stated a 3/8 drive 15mm socket works then the 7mm retaining screws, lift out the plastic cowl cover look for debris down in there.
I looked up under my dash board on the passenger side and don’t see that drain hose , it’s on the engine side of the firewall .
Old Jul 20, 2020 | 04:31 PM
  #36
and a how to get under the cowl, check to see if the cowl has a patch on yours , being a 2009 it shouldn’t, but that drain could be blocked
Old Jul 20, 2020 | 08:36 PM
  #37
Mike Fry's Avatar
I didn't see any when replacing the windshield wiper transmission,but I'll pull it apart and look at that other oval piece you posted,might be a couple days before I can,thanks again for the help,I'll let ya know what I find when I get to it
Old Jul 24, 2020 | 08:45 AM
  #38
Mike Fry's Avatar
Well,drain is not clogged, but the evaporator box is cracked and leaking like hell,so I don't know what to do now,thanks for all the help,not sure if I can do this myself,or wanna put that much money into an 11 year old car,sucks cuz it still runs great
Old Jul 24, 2020 | 08:52 AM
  #39
Can you get at the cracked pan and either spray or tape it with Flex Seal?
Old Jul 24, 2020 | 01:44 PM
  #40
Mike Fry's Avatar
I wouldn't know how,the guy that found it today used a small camera and showed me the video,but I've been looking and looking for how to take the dash apart to do it,and all I've found is just how to remove the center around the stereo,if you have a link or something that would show me how to get in there I'd appreciate it
