disengaged engine/need car guys help!
i have an 07 2.2L a couple of days ago i was on my way to work and it seemed when i hit the gas pedal the engine shut off, the digital read out said engine disengaged.i pulled over and it wouldn't turn over,i waited for about 5 min and it started.
im not car savvy,but the dealer did clean the fuel system in jan 2011 for 60k maintenance....maybe they messed up???
it starts and runs now but my car definitely does not feel the same.it still is under warranty but if the dealer does not find anything wrong or if the prob is not covered i have to pay 100.00$ and $ are kinda low right now.
..............ANY HELP will be APPRECIATED...................
Hmmmm,
seems like a bad way to provide customer service/loyalty BUT a good way to build revenue. Let's see.....can't find anything.....can't find anything........can't find anything.......oh, yeah, here it is. So that's $300 because of technician incompetence. Then they will try to convince you the fix they did find, is not covered under warranty. So another....$XXXXXX.
I wonder if those charges comply with GM's Warranty Coverage.
You should check on that !!!
chevhhrdummy
Sep 30, 2014 07:48 PM
Robb
Jan 15, 2014 10:30 AM
ahuschka
Aug 25, 2013 07:22 PM
menance
Dec 22, 2010 06:14 PM
