Driver door
Old Oct 23, 2022 | 11:29 AM
HHRnovice's Avatar
[QUOTE=greg8453;930938]I said it's NOT sag.[/QUOTE
Yes, I didn't see your reply until after I posted about the other doors. My bad.
Old Oct 23, 2022 | 11:37 AM
HHRnovice's Avatar
Looking at the picture, the door gap to the fender gets wider as it goes higher. Take a look at the door hinges. The bushings and/or pin on hinge is probably bad.
Open the door. Lift up on the bottom of the back of the door. If there is any vertical movement or “looseness” then the hinge is bad.
If the hinges are good I would then look to see if the car has been hit in the front and pushed the fender back.
I noticed the widening of the gap too and tried to lift the door as you said but it's solid, no movement. I've had the car for a few years and I don't believe it's been hit in the front. There are no dents or damage on the front.
Old Oct 23, 2022 | 11:41 AM
HHRnovice's Avatar
Originally Posted by donbrew
You can adjust the fender. Loosen all the bolts then use a large screwdriver or other tool in the openings at the top to move it, then with your other 2 hands tighten the bolts.
I will do this and see if it helps. Thanks.
Old Oct 23, 2022 | 03:02 PM
Could be just #1 and #2 are loose.
Old Oct 23, 2022 | 09:11 PM
greg8453's Avatar
How does the other side look? Is it square with the B pillar?
It's easy to tell by looking at the whole door and then some.
Allen P
Oct 17, 2020 08:15 AM
sking1973
Maintenance and Upkeep
Feb 21, 2014 05:30 PM
hhrlover101
Oct 5, 2012 12:23 AM
Rikki Sixx
Jan 6, 2009 08:30 PM
Biff
Dec 29, 2008 09:00 PM
