Driver seat heater indicator blinking
Old Oct 19, 2010 | 08:01 AM
fishlab's Avatar
Hello to ALL!!!
I have some problem with driver seat heater. If I try to switch it On then indicator just blinking and seat is not heated. Passenger side works fine. I suppose that is control module fault? Fuses seems to be OK if I right check it by manual instructions. If anybody get same problem or can consult me? Thank you for any response.
PS Probably it is already described somwhere here but search not give me any luck, sorry
Old Oct 26, 2010 | 10:11 AM
fishlab's Avatar
So no one meet this problem? I wonder with it...
Old Oct 26, 2010 | 05:38 PM
Lucky's Avatar
I had this happen to mine last winter. it only failed to work until the next time I started the car then it worked fine and has not failed to work sence. I beleve that when the light is flashing that there is a fault in the system.
johnsHHRSS
Jul 30, 2010 05:45 PM
Cardwiz428
May 17, 2008 12:42 AM
Harpozep
Jan 5, 2008 10:41 PM
Juli
Aug 7, 2006 04:28 PM
