Drives only in reverse
34 is is the crank relay 43 is the trans fuse.
I was just pointing out you could have done something while in the fuse box.
We may be talking about different things; exatly which fuse in which fuse box did you change? I don't see any fuses underhood for power windows.
the fuse for the power windows was in the engine area and was number 36. It was a 30 amp fuse.
