Drove through water, now having issues
Old Sep 28, 2014 | 12:27 PM
Leica's Avatar
Recent deluge here in FL had our '06 HHR driving through some deep water, not deep enough to get into the intake, however the idle is higher than normal now (1k rpm), the car is vibrating like it has bad motor mounts, and the A/C compressor kicks on and off constantly with the A/C on. The compressor is the lowest accessory on the motor and was probably under water for a period of time, is it possible the compressor is causing the symptoms? The idle remains high whether the a/c is on or off.
Thinking about resetting the ecu but I'm not too hopeful that it will do anything. Any ideas on what it may be?
Old Sep 28, 2014 | 12:57 PM
LawDog88's Avatar
Try it and report back.
Old Sep 28, 2014 | 02:49 PM
Leica's Avatar
Reset ecu, no change.
Old Sep 28, 2014 | 03:21 PM
My guess is water in one or more electrical connectors. Disconnect each one and dry them out.
Or, water on one or more sensor.
Old Sep 30, 2014 | 07:38 AM
Blue_SS's Avatar
The A/C has a pressure sensor that normally shuts the compressor off when it is at its top pressure. A short could easily be resulting in false signals...
So, yeah, basically, what that guy ^ said...
Old Sep 30, 2014 | 11:15 AM
07azhhr's Avatar
If the compressor was under water then so was the crank and it's sensor. Those might be the first connectors to start with.
LuckyLadySD
Jun 12, 2014 02:09 AM
vlxk98
May 10, 2013 06:21 PM
SandyBeach
Aug 31, 2009 07:36 PM
SLOWHITE
Jan 31, 2008 01:44 PM
bigallis1
Apr 8, 2007 01:46 PM
