Electrical issue, speedometer gauge bounces up and down, trouble shifting into gears
Old Jul 1, 2024 | 06:20 PM
hvacgerardo's Avatar
Hello everyone, I just got this Chevy hhr 2010 and I’ve been having issues with it when I accelerate. Every time it feels like it’s going into the next gear it bounces and doesn’t catch the gear, I have to let go of the gas pedal and press it again as needed in order to shift on the the next gear. My thermostat gauge on my dash sometimes doesn’t work, my AC sometimes turns on, no codes are being found either, any suggestions?
Old Jul 1, 2024 | 06:55 PM
Welcome
You’ve got codes. Your reader just isn’t picking them up. Make sure your reader is powering up at the OBD port. If not, check fuse #29 engine compartment fuse box.
Or try a different scanner.
Old Jul 1, 2024 | 08:17 PM
to the forums!
The four 7mm bolts inside the underhood fuse block, crank them down super tight.
Old Jul 1, 2024 | 09:25 PM
Change your T-stat use a ACDelco 131-158 ONLY!
Old Jul 2, 2024 | 06:49 AM
And change the Dexcool, it has a shelf / service life of 5 years.
Byroon
Aug 3, 2023 10:42 AM
ScottyB
Jun 8, 2023 10:40 AM
Misael622
Nov 23, 2015 08:04 AM
bad03xtreme
Aug 14, 2009 07:03 PM
Black Rose
Feb 16, 2007 06:08 AM
