Eng mount thunk
Old Apr 21, 2009 | 10:05 PM
IgottaWoody's Avatar
Eng mount thunk
Anybody experiencing a thud when in low gear less then 10 mph in low gear?
Feels sounds just like a loose eng/trans mount or a torque link..havn't got my lazy butt under to look yet..( weather not being cooperative either)..have 14k miles...oh , it happens when you left off or get back in the gas
Old Apr 22, 2009 | 12:11 AM
prod's Avatar
Sounds like the sway bar end links are a good possibility.
Could be tranny related, but not many people have problems with that.
Old Apr 22, 2009 | 05:43 PM
not a sway bar..definitly eng/trans related..sounds like a loose/worn torque link if these cars have them, otherwise will check mounts..will be looking into this weekend....
Old Apr 23, 2009 | 04:09 AM
masterchief1112's Avatar
check the top eng mount, on the passenger side. i had a few little noises out of mine, torqued it down, then all gone
Old Apr 26, 2009 | 01:49 AM
Gotta look see today..need to compare notes.....can someone check and see how much movement there is when you shift between rev - n - drv? Seems to me there is a bit tooo much play on the lower aft mount..aso getting a tranny noise in neutral, sorta like a rattle
but not. Also getting a tink noise which I believe is contact on the backside...I'd say I'm getting about 2 in of movement at the valve cover, eng defnitly rolling over.
guille2228
Feb 22, 2014 11:10 AM
Grimesy
12
Aug 19, 2012 11:34 PM
dino9832
Aug 19, 2009 02:15 PM
lake
Feb 8, 2009 11:32 AM
JonyyB
Sep 27, 2005 06:06 PM
