engine harness electrical connector
Old May 16, 2011 | 08:36 AM
geg's Avatar
geg
it seems, Russian electricians learn from other textbooks. I've never seen anything like it.
I'm more inclined to think that the to very few people in Russia need dielectric grease.
Old May 16, 2011 | 07:05 PM
BlackknighT's Avatar
What about alternator & starter rebuilding company?
Old May 17, 2011 | 02:46 AM
geg's Avatar
geg
idea!!!
good
Old May 17, 2011 | 06:12 AM
If that doesn't work, most ignition wire companies put a small packet of the grease inside the box of ignition wires... The packet could accidentally fall out of the box...
The packet of grease usually looks like the attached link with picture, but small, about 1.25 inches long, and sometimes has no writing on it. (sorry it's a hyndai link but it had the best picture)
http://www.gencoupe.com/vendor-class...our-order.html
Old May 20, 2011 | 03:09 AM
geg's Avatar
geg
bought a small amount of dielectric grease.
found with difficulty. paid crazy money - 3,5 dollars for 5 grams.
That's enough for the first time. Waiting for delivery from the U.S..
Old May 28, 2011 | 01:56 AM
geg's Avatar
geg
Here, the mother ...
Today, i clean the connectors and dielectric grease lubrication. The procedure cost $ 35, 45 minutes of time and one packet of lubricant (see previous post).
So far everything is OK.
My friend sent me a big tube of dielectric grease, be a good stock for the future.
Old May 29, 2011 | 07:54 AM
Gas Man's Avatar
Wasn't this a corrected issue on later models?
Old May 30, 2011 | 11:21 AM
geg's Avatar
geg
I'm sorry if I do not understand you correctly.
If you're asking whether the problem is corrected in later models HHR - I do not know.
I think that the HHR is poorly adapted to the Russian roads. This is not the fault of the GM, they did a car for a "soft" conditions. But ... Connectors rust, suspension is falling apart, duct sucks the dirt from under the right Fender.
Old May 30, 2011 | 01:16 PM
Sno White's Avatar
geg has a 2006 he imported into Russia, so the vehicle is an older model.
Old May 30, 2011 | 08:07 PM
Gas Man's Avatar
That was what I was asking. I was hoping somebody else would comment.
I understand what you mean about the ruff conditions you are putting your HHR through.
