Engine light
Old Feb 20, 2010 | 10:15 PM
LONALA's Avatar
Engine light
My engine light just came on the dashboard. Does anyone know about this? We all assume it needs service. I only have 27900 miles.
Old Feb 20, 2010 | 11:13 PM
jay loukakis's Avatar
I had the same problum the air filter had come out of the fender opening pluged it in fixed the problum.
Old Feb 20, 2010 | 11:16 PM
harleysshhr's Avatar
Did you check to see if your gas cap is tightened properly?
Old Feb 21, 2010 | 01:44 PM
skyeglen's Avatar
A lot of the bigger chains of auto parts stores will read (and clear) the code for you for free. Call around and you should be able to find one that will do it.
Look up the code on this site and you will know what direction to go to fix the problem. Post what the code is and someone will hepl you.
Old Mar 2, 2010 | 10:45 PM
LONALA's Avatar
It was the gas cap, it was loose. The Dealership quoted me $124.99 to reset. They stated they do an on-board diagnostic and find out the problem then reset the light. I say "ridiculous"! Any other suggestions people?
I appreciate your assistance! ...
Old Mar 2, 2010 | 11:25 PM
"Any other suggestions people?"
Yes, avoid stealerships, post your problem here first..Many here have answers..
Some Dealerships are better than others, in keeping a customer happy..
Old Mar 3, 2010 | 07:25 PM
ChevyMgr's Avatar
Disconnect the battery for 30 or more minutes will probably clear it. Or it will clear it self from being a current code and displaying in the IPC after driving for a week or so. It is then stored as a history code which won't affect anything.
Old Mar 3, 2010 | 10:54 PM
Right on. Evap leak code will clear itself if it is a small leak and it is corrected. (cap being tightened properly) The light will turn off itself but the history will stay.
Old Mar 4, 2010 | 10:06 AM
LONALA's Avatar
Hey guys!...I forgot I have an OBD II reader which reads out codes. I simply hooked it up which read me the code and I simply erased it. It resets it, that easy. Puchasing an OBD reader can save you money!
The engine light on the dashboard also deletes the remote engine start.
Old Mar 4, 2010 | 11:05 PM
IgottaWoody's Avatar
Gotta love modern technology....cars now are getting as bad as programming an old VCR
purple people eater
Sep 17, 2016 01:07 PM
Johnhern777
Apr 21, 2014 05:26 PM
flooprigger
Aug 4, 2013 08:58 AM
jmpnjoe86
Mar 10, 2013 06:13 PM
jmarines
Feb 17, 2009 11:43 PM
