Engine swap - '09-11 motor in '07?
Old Aug 12, 2015 | 10:05 AM
Nvizn's Avatar
Contacted the suggested junkyard and he stated it doesn't matter whether the donor is drilled or not. Good to know.
Old Aug 12, 2015 | 10:58 AM
Ahhhh, relief now get that engine swapped out and start running your HHR, careful of your torque settings and replacing all the ground wires and sensor connectors
Old Aug 12, 2015 | 11:01 AM
Nvizn's Avatar
Originally Posted by Dbeluscak
And on a side note to your original issue. I had a blown head gasket, engine temps in excess of 250*. I had no oil and water mixing. Had a blown seal around cylinder 4.
Good luck on your "adventure"
I do not know the history of the vehicle, whether it overheated, etc. I purchased it 6-8 weeks ago from the previous owner, in and aware of its current condition. He had no interest in resolving the problem.
Old Aug 12, 2015 | 09:23 PM
Nvizn's Avatar
The motor I was considering, was sold out from under me. Ended up with a 95k 2.2, which cost me an additional $100.
Old Aug 12, 2015 | 09:57 PM
So. What year engine did you wind up getting ?
Old Aug 13, 2015 | 06:11 PM
  #26
Nvizn's Avatar
2008, pulled from a Pontiac G5.
Old Aug 13, 2015 | 06:25 PM
  #27
Great the swap begins!
Old May 22, 2017 | 10:23 AM
  #28
Tim Coole's Avatar
Originally Posted by Nvizn
Thanks for the response. What specifically, varies with the block?
Accordingly to Wikipedia, it appears they're all the Ecotech L61 I4.
https://en.wikipedia.org/wiki/Chevrolet_HHR
To add to this conversation, compatibility with the 2.4 liter?
i have an 07 2.2 and I just put a 2.2 vvt out of a 2010 I took the whole subframe out of the 2010 tranny engine and all. Then put in mine I am facing anti theft issues now but I think I will get it to work I will let u know if I do
KCCO
2.2L Performance Tech
29
May 2, 2015 05:59 AM
guppy
Mar 30, 2015 08:18 PM
skuzzlebutt
Mar 31, 2014 02:50 PM
SwaintaN
Maintenance and Upkeep
15
Jan 25, 2014 01:14 AM
xzombie
2.4L Performance Tech
Sep 1, 2009 02:18 PM
