extra glove box sticks
Old Nov 11, 2014 | 09:33 PM
leesadb1's Avatar
Does anyone have this issue or know how to fix glove box on dash? I have to use a credit card to slide thru hinge and open up im just a bit annoyed after spraying a bottle of wd40. I also have read thru most forums seems like most people have liftgate issues mine went out with 3 loads of laundry and groceries.. yay!!! NOT....... anyways so now that I have read im going to try to check fuses even if I dont own a manual or diagram yay again! wheres my advil..
Old Nov 11, 2014 | 09:45 PM
Welcome to the site.
Just venting I guess.
But, the facts are you've got a 8-9 year old car. Things do wear out.
Glove box fix ? Sure. Do a search here. It's been discussed before.
Lift gate "went out" ? You also stated most people have liftgate issues ? Don't know where you came up with "most people". That's just not a true statement.
I'm guessing you mean the struts won't hold it up. Like stated, it's a 8-9 year old car. Parts(struts) do wear out. Get some new ones (if that's the problem) and it should be good to go for a number of years.
No owners manual ? We've got them "free" on this site for download. https://www.chevyhhr.net/forums/gene...s-manual-3074/
An FYI. Most of the fuses and relays are labeled as to what they go to.
Old Nov 12, 2014 | 07:41 AM
Grizzly old man's Avatar
Go see if you can trade the Advil for some Valium. ;}
On my '06 I discovered that when I push the button in to open the center storage compartment {extra glove box} if I pull back with my fingers on the edge of the button hole it will open right up.
My rear hatch didn't open all the time but it did easily enough most of the time. I applied a whole bunch of WD-40 and washed a ton of crap out of it and that seems to have fixed it for me.
Old Nov 18, 2014 | 08:36 PM
leesadb1's Avatar
thank you.. Grizzly appreciate that turned out hatch relay went out. I do understand I have an older model so it was expressed ... Just wanted to see what anyone would say to help thanks again now time to figure out why my fuses keep shorting out on rear lights. 2nd time around tata
Old Nov 18, 2014 | 11:43 PM
Twistedtat's Avatar
My dash glove box had an issue opening. Turned out I was missing one 9f the rubber bumpers under the lid. After I put the new bumper in no issues. Just a suggestion.
DjLBM
Dec 16, 2024 10:12 AM
FLORIDA
Sep 26, 2009 03:16 PM
KY Dave
Aug 28, 2007 10:29 AM
calgaryhhr
Apr 14, 2007 05:32 PM
TomsHHR
South Central
Aug 8, 2006 03:51 PM
