Faint squeaking noise when engine is running
Yes they can Mike. Right before they lockup. But, in the old days, I've heard ones make some small chirp like noises also. Remember,it's a bearing,so it could be prone to different noises as it slowly fails.
Very true George, I think donbrew is on track with recommending the OP invest in a Mechanic's Stethoscope, very handy gadgets and inexpensive.
Just don't get one in the "wrong place" while the engine is running, I slipped on day working on a Malibu with a 396, thought I'd lost my ears when the water pump pulley ate the stethoscope.
I've ruled out any component that I can see. As far as I can tell, the squeaking sounds almost like a shot bearing because it sounds like a squeaky wheel on an old office chair. The sound doesn't seem to get louder when the RPM's rise, I really only notice it at idle. I'd heard that there's some type of fan that tends to start squeaking on a Cobalt, but I can't remember specifically which one it's supposd to be...possibly something on the AC? but even when the AC is off I hear it. That being said, I'm not sure if it's the same exact component as the Cobalt would have...so I'm flying blind. I researched the damn car for 6 months before buying it, but this little foible escaped my extensive research and inspection....
I hope the replacement of the wheel will get this taken care of.
True Don, very true, it would be worth it for the OP to scoot under and check around the pump for leakage which can sometimes accompany a wonky pump bearing. Honestly I don't know if HHR water pumps have a weep hole as a telltale for when the bearings or seals start to let go.
I'm kind of in agreement with an idler pulley or the belt tensioner. Using a stethescope to pinpoint the source is a good idea. Of course all these long distance diagnostics are only guesses and suggestions.
