Fan noise (vent/AC, not engine)
I only speak the one language, I don't know how to be any clearer.
"Pull the cabin filter back out and fish around to pull/vacuum the debris out, that is the only access point. "
Otherwise you must CUT the motor & fan out of the housing and replace it with a new unit. You CANNOT simply pull the fan out(PERIOD).
Start that project by using the search tool which will lead you to the Correct Thread for this problem.
