Flashing Dash Lights!!
Old Nov 20, 2018 | 09:24 AM
Good, just confirming, they tested it properly.
Old Nov 20, 2018 | 09:45 AM
piper27's Avatar
I just went out and tested the battery myself. Not sure I'm doing it right but doing it according to a video I found. I turned on the headlights for 2 minutes to remove surface charge, then checked with multimeter got 12.43 volts, tested while cranking and voltage went down to 11.3 volts. While running reading shows 14.72 volts. Does anything seem suspect?
Old Nov 20, 2018 | 10:08 AM
Dead battery. Might need a new alternator; the output should vary some according to needs.
Old Nov 20, 2018 | 10:09 AM
The drop to 11.3 volts indicates a problem
Old Nov 20, 2018 | 10:23 AM
piper27's Avatar
Thanks for all the help, I'm going pick up a new battery. I didn't realize 12.43 volts put it at 65% charged.
Old Nov 20, 2018 | 10:33 AM
It’s sad, but it’s not 1964 anymore, all the computers and management sensors require full power at start up, it’s not just a matter of turning the starter and getting some spark to fire up the engine.
If the charge is weak, the battery is done.
Old Nov 20, 2018 | 02:50 PM
piper27's Avatar
Put a new battery in. So far so good. Thanks all
Old Nov 20, 2018 | 03:18 PM
Enjoy the drive!
Old Nov 20, 2018 | 03:33 PM
Now that you have a known good battery get the alternator tested.
Old Nov 21, 2018 | 06:41 AM
piper27's Avatar
Yes, will do
