flexuating idle while driving on my HHR
Old May 11, 2020 | 09:18 AM
The lobotomy is really a simple reset of the HHR’s computers, disconnect the ground terminal at the battery for 30 minutes.
It’s always been my practice to avoid shocks or sparks, or frying electrical components to disconnect the battery while working on the engine or the fuel system, even the wheel hubs in the ABS equipped.
You do not need to disconnect the positive cable unless you’re changing battery’s , in which case be very careful to ensure the positive cable doesn’t touch the negative cable or the body, this can cause issues in the RAP system, I fried the radio in my 2007 last summer.
Old May 11, 2020 | 12:19 PM
Bonez's Avatar
Originally Posted by 1bikenut
I will buy some throtle cleaner tomorrow. My mechanic said he sprayed it but he didn't mention anything about taking it out and spraying the back side. Thanks for the tip. I will keep you updated.
You cant manually move the throttle plate to clean ( can damage it ) so it has to be removed to clean the "inside" aka back side... get a soft brush to scrub it, you don't want to use anything harsh.
Old May 11, 2020 | 12:21 PM
Bonez's Avatar
Originally Posted by Oldblue
Yes that surge when doing 40 mph is a similar problem. It could also be a vacuum leak , but that would thro a code.
Being these HHRs are drive by wire, would dirty contacts cause that as well in the pedal? Use some contact cleaner maybe?
Old May 11, 2020 | 02:40 PM
Can do, but unlikely it will help. The last TCM update was in 2008, it helped my ‘07 , but it’s the same programme in my ‘11.
dirty throttle body
dirty engine oil
dirty MAF sensor
vacuum leak, in my case the EVAP valve was leaking, only set a code every other fill up.
Old May 11, 2020 | 07:31 PM
skysailor's Avatar
I did manage to clean both sides of the throttle plate by having someone sit inside the car with the key turned to ON and depressing the accelerator pedal. That made the throttle move to full open and allowed me to spray cleaner on it enough to clean it very well. Note that it did not start easily the first time after doing this due to the flooding with cleaning fluid. :)
chattycatty
Apr 29, 2018 05:08 PM
Ryan Beam
Aug 17, 2016 09:11 AM
jbrown425
Aug 8, 2013 05:24 PM
beachbum1970
Mar 25, 2009 08:46 PM
