front-end clunk/rattle
Old Sep 24, 2018 | 12:51 PM
  #41
Note Oldblue said "CHECK", not "REPLACE". Without CHECKING and diagnosing the problem, one can throw lots of $'s at it and still not resolve the problem.
Old Sep 24, 2018 | 01:13 PM
  #42
As Oldblue said: "Check the swaybar bushings, then check the rear bushings in the lower control arm.". Never mind, you just deleted your post.
Old Sep 24, 2018 | 01:18 PM
  #43
Frisco57's Avatar
Sorry whopper & OldBlue That's great advice! I deleted my post by mistake. New here, still trying to navigate this ChevyHHR.net
Old Sep 24, 2018 | 01:35 PM
  #44
Follow the link in my sig.
Old Sep 24, 2018 | 01:52 PM
  #45
That’s the best advice, Don has a link to lead you thru what to look for, trust me , and be encountered every thump clank and grind over the years and investigation is a lot less money then just ordering parts.
Old Sep 24, 2018 | 03:55 PM
  #46
Cat Man HHR's Avatar
Originally Posted by Frisco57
So I've just started to fight this "front end clunk noise" on my recently purchased 09 HHR by replacing the sway bar links. I installed the Moog ones with the grease fittings. Sadly, it still clunks at low speed when going over small bumps. What is my logical next step, what should I try next?
I have 50K on mine and have slight "clunk" when going forward or backward over small "bumps" when turning to lock. I have the Moog sway bar links and the sway bar bushings are good along with the rear LCA ones.
I installed new Delco front struts but used my OEM springs and top plates. Mine is an SS. When I inspected the top plate bearings I didn't see anything abnormal, otherwise the parts would have been replaced. Still have the "clunk". Maybe it is the top plate ?
Old Sep 24, 2018 | 04:06 PM
  #47
This happens when turning the wheel to lock?
Then: the plastic stops on the sway bar, on the inner side of the bushings, may have moved or disappeared. And/Or, the end links are the 12 inch variety and they are banging into the LCA.
Old Sep 24, 2018 | 04:14 PM
  #48
It could be your upper engine mount, or steering rack input shaft, a tie rod or front bumper cover
Old Sep 24, 2018 | 08:02 PM
  #49
Did you grease them?
Old Sep 24, 2018 | 09:16 PM
  #50
Frisco57's Avatar
You bet! Have fittings,will grease!!!
